Cognex Introduces DataMan 200 ID Reader
April 29, 2009 by
Filed under Sensors/Vision
  • Sharebar
dataman 200 line lowres 300x279
The DataMan 200 ID Reader from Cognex features Ethernet connectivity and liquid lens technology. It is an image-based reader which features full Ethernet connectivity in a package the size of a matchbox as well as liquid lens technology, ideal for applications with variable focus requirements.
Ethernet connectivity gives DataMan 200 users the advantage of real-time data and image transfer, and easier integration with plant controllers and information networks. Liquid lens technology, an optional feature of the DataMan 200, provides greater focal range, ease of setup, and faster response time. This unique technology adjusts the camera’s focus by applying an electrical charge to fluid within the lens.
Liquid lens technology enables autofocusing with a single software command. The lens also provides exceptional depth of field and field of view range, and, because it has no moving parts to malfunction or break down with use, the system is extremely rugged and resistant to shock, vibration and wear.
Setup is simplified with the use of two laser aimers. The laser targets are easily seen through the entire depth of field, enabling operators to quickly position the code to the reader.
The DataMan 200 features an easy-to-use interface for setting up applications, and supports a wide range of 1D and 2D codes including UPC/EAN/JAN, Code 39, Code 128, Code 93, Interleaved 2 of 5, Data Matrix, QR Code, and micro QR Code.
Visit Cognex on-line at www.cognex.com.
Comments
