Now, Miki Pulley directly sells CSZ Electromagnetic Actuated Clutches to OEMs in North America.
These CSZ Clutches have zero-backlash design. They function utilizing the magnetic force generated by the energized coil providing engagement of input and output members of the clutch. They provide an efficient connection between a motor and a load with low inertia, minimal drag and zero backlash. More after the jump.
Miki Pulley CSZ Clutches feature an integrated bearing design making mounting fast and easy while ensuring application concentricity and excellent system runout. CSZ Clutches operate well in temperatures from +14°F to +104° (-10°C to +40°C).
Available in bores ranging from 10mm to 15mm, with brake torques ranging from 1.77 ft. lbs. to 7.376 ft-lb (2.4 Nm – 10 Nm). The CSZ utilizes corrosion resistant materials, and is RoHS compliant like all other Miki products.
“Miki Pulley’s CSZ Clutches excel in high-performance printing, paper processing, packaging, food processing and textile manufacturing systems,” said Jon Davidson, Miki Pulley sales specialist. “They are proven performers in system applications around the world.”
For more information about Miki Pulley CSZ Clutches, email Jon Davidson at jdavidson@mikipulley-us.com.
