G4 Canstack Linear Actuator from HaydonKerk
April 28, 2009 by Miles Budimir
Filed under Actuators
The G4 Canstack Linear Actuator from HaydonKerk Motion Solutions is the 4th generation design built for extended reliability and high performance. The first actuator to be released in the line is the 25mm diameter. The new design uses optimized teeth geometry along with high-energy neodymium magnets.
With 20 percent higher output force across the entire speed range compared with previous designs, the G4 also contains the latest custom engineered plastic molded threads and an over-sized spline for a more robust and better life product. Additionally, the use of larger bearings provides greater rotor support and higher axial load capability.
The G4 Canstack provides exceptionally high torque-to-size ratios and is ideal for a variety of applications, including medical equipment, bar code scanning devices, printing equipment, laboratory instrumentation and other mechanisms requiring high force in a small package. Three configurations are available as with other Haydon stepper motor linear actuators; captive, non-captive, and external linear.
For more information on the G4 Canstack, contact HaydonKerk Motion Solutions at info@HaydonKerk.com
Comments
