Linear Cable Transducer from BEI Industrial Encoders
  • Sharebar
BEI Industrial Encoders’ new linear cable transducer provides digital position and speed feedback information in a rugged, easy-to-install package. Model LT25 cable transducer utilizes a flexible measuring cable mounted to an internal spring-loaded spool and a quadrature encoder output to precisely measure linear motion applications. The sturdy cable is made of nylon coated stainless steel for ultimate strength and has a measurement range up to 125 inches.
lt25
Easy to install, simply connect the LT25 cable to your moving equipment and secure the base to a fixed object. Hard to reach areas or worries about shaft misalignment are now not a problem. The LT25 cable transducer allows for easy reorientation of the mounting bracket or encoder connector position, giving users added adaptability to their installation. With an IP66 rating, the LT25 is a perfect solution for a variety of industrial measurement challenges including wet, dirty, or outdoor environments or applications where your measuring range travels over a harsh environment.
www.beiied.com/cable-transducer
Comments
