Stäubli Robotics Announces Next Generation SCARA Robot Series
June 19, 2009 by
Filed under Robotics
  • Sharebar
staubli
Stäubli Robotics, manufacturers of innovative and technologically advanced industrial and cleanroom robots, announces the new TS series of high-speed SCARA robots. This next generation robotic line features 100% Stäubli design and engineering, and are among the fastest commercially available SCARA robots in the industry. Stäubli’s high performance benchmarks of speed, rigidity and precision are exemplified by this series which includes the TS40, TS60 and TS80 with a range of 400mm, 600mm, and 800mm reach and a payload of up to 8kg.
All TS series robots feature four-degrees of freedom, a hardened plastic external housing and electric servo-driven motors for reliability. These robots use the CS8C controller which features a compact lightweight design and is the most technologically advanced controller ideally suited for applications that require complex process control. The CS8C utilizes the VAL3 programming language which is perfectly adapted to robotics and features numerous possibilities to communicate with the outside world including several different Fieldbus options, Ethernet, ModBus, and an offline programming software package (SRS) for ease of integration and use.
The TS series is highly adaptable and well suited for a wide variety of high speed and precise applications including pick and place, material handling, packaging, assembly, loading, testing, and dispensing. These new robots increase productivity and throughput without giving up valuable floor space making them ideal for food, pharmaceutical/medical device, automotive, electronics, and many other industrial market segments.
For more information, visit www.staubli.us.
Comments
