Wittenstein’s Ternary Actuator Released with New Options
February 12, 2010 by
Filed under Actuators, Featured
  • Sharebar
Ternary has been known as the Intelligent Integrated Actuator for nearly a decade. Since this revolutionary product came into the industrial world, it has developed beyond simply a standard actuator. The new options that the Ternary now offers allow customers to mix-and-match their requirements to choose the product the application needs.
Wittenstein Ternary
New control interfaces: Ethernet/IP and Analog Position Control
* Ethernet/IP
o Supports 10/100 MB communication
o Makes setup simpler
o Eliminates Expensive accessories
o Same Programming Format as our Devicenet Communication
* Analog Position Control
o 0-10 VDC or 4-20 mA input for Position Control
o Ideal for Proportional Valve Control / Flow Control
Other recent additions to the Ternary line include
New IP40 Protection class
* Available with either Robust or Economical connectors
* Savings of up to 30% from IP65 version
New 200 and 400 Watt Rotary Servo Actuators
* Increase your output with new 100 mm frame size motor
* Available with all standard Fieldbus interfaces
* 110 or 220 VAC direct Power input
* Available with or without gearboxes
* Ideal for distributed control applications
The new Ternary catalog is also available for download from www.wittenstein-us.com/tech-support/manuals.
Wittenstein
Comments
