You are here: Home / Encoders / 16 Dip Switch Programmable Resolutions
The AMT102 or 103 VersaPak model comes standard with an onboard dip switch with 16 selectable resolution options ranging from 48 to 2048 PPR.
It also includes an index pulse as standard. The output is TTL voltage and the operating temperature is -40° C to 100° C. The AMT is available in two mounting options: AMT102 is radial (straight orientation) and AMT103 is axial (right angle orientation). The AMT is capacitive and not optical, which eliminates handling of the sensitive optical disk and issues related to LED burnout from the photo diode.
CUI
www.amtencoder.com
Filed Under: Encoders Tagged With: programmable resolutions
