You are here: Home / Networking + IoT / I/O / 20 New Accessories for WAGO’s TOPJOB®S Terminal Block Line
Germantown, Wis. – Twenty accessories, including WAGO-exclusive models, have joined WAGO’s TOPJOB®S Terminal Block family. The accessories include Modular Connectors, Vertical Jumpers, Colored Jumpers and Component Plugs.
Modular Connectors, Push-in Jumper Slot Connectors and exclusive Conductor Entry Connectors can be configured for test harnesses or serve as permanent pluggable connectors. TOPJOB®S terminal blocks have an exclusive retention spring for vibration-proof connections of jumpers and modular connectors.
TOPJOB®S Vertical Jumpers convert a multi-level terminal block into a common potential. Available in two- or three-levels, Vertical Jumpers streamline stocking by specifying one multi-level block and field-modify with appropriate jumper for potential conversion.
Colored Jumpers are available in red or blue and from two- to 10-pole configurations. Colored Jumpers can be used to indicate positive (+) and negative (–) signals for sensor applications.
Among nine Component Plugs are a mini-PCB-compatible variant and component plug model that inserts into the jumper locations of two adjacent TOJPJOB®S terminal blocks. The jumper-compatible model also features an integrated retention spring for vibration-proof connections. Component Plugs create custom products by adding diodes (backlash protection), small resistors (signal conversion or leakage current) or mini-PCBs (custom circuits).
To find out more, email [email protected]
www.wago.us
Filed Under: I/O
