You are here: Home / Industry News / Applied Motion to exhibit integrated servo motors, servo drives, stepper drives at Automate
February 22, 2019 By Paul Heney Leave a Comment
Applied Motion Products will demonstrate a selection of new integrated motors and drives for both servo and stepper motors in Booth #8147 at the Automate Show to be held at McCormick Place, Chicago, from April 8-11, 2019
Products on display will include the following:
• MDX Integrated Servo Motors that combine high torque density, low inertia servo motors with on-board drives and controllers to create all-in-one integrated motor solutions that save on space, wiring, and cost over conventional servo systems with separate motor and drive components.
• StepSERVO Integrated Motors that provide cost-effective and high-torque motion control for high throughput applications such as packaging and labeling, automated test and measurement, and automated assembly.
• STF Stepper Drives that support a range of industrial Ethernet and Fieldbus network protocols including EtherCAT, EtherNet/IP, CANopen, Modbus, Ethernet and RS-485, as well as a proprietary Serial Command Language (SCL) for efficient network communications over Ethernet (UDP or TCP) and RS-485. Using STF Stepper Drives, system designers and machine builders have the flexibility to control step motors using the network protocol of their choice.
• SV200 Digital Servo Drives that operate on 24, 48 or higher dc supply voltages for space-constrained and multi-axis motion control applications.
www.applied-motion.com
Filed Under: Industry News
