You are here: Home / Motors / Applimotion Direct-drive Frameless Motors Feature Larger Through-holes
Loomis, CA – Applimotion’s ULT Series now offers some of the thinnest radial cross-section motors available. Whether its an optics application with line of sight through the motor’s center, or a need to maximize the wiring payload in a slip ring gimbal system, these motor can help. Initial sizes in the 2.5 and 4.5 in. diameter are offered. Future sizes are planned.
1296_StatorRotor (Aug 09)
These motors remain true to the ULT ultra-thin origins with low-profile construction. ULT motors operate using standard three phase brushless DC or brushless AC drivers with voltage ranges from 12-300V with Hall device options also available.
There is no need to only go slow with Applimotion ULT motors. Direct Drive doesn’t necessarily mean low speed. Speeds of up to 10,000 rpm can now be achieved with the correct electrical match between the motor and driver.
www.applimotion.com
Filed Under: Motors
