You are here: Home / Mechanical PT / Bearings / Aurora Bearing Co’s LCOM Spherical Bearings
March 11, 2009 By Motion Control Tips Editor Leave a Comment
Like all Aurora Bearing spherical bearings, the LCOM series features a one piece steel raceway, swaged around the ball for a smooth, precise, close tolerance fit, along with the benefit of the strength and vibration resistance of steel. In addition, this series is optionally available with Aurora’s proprietary AT series PTFE liner, for a zero clearance, self lubricating fit.
Aurora LCOM Spherical Bearings were designed to offer a higher level of performance with dimensional interchangeability for the “LS” spherical bearing category; a market segment which has remained largely unchanged since the 1950s. “LS” bearings are characterized by being of 3 or 4 piece construction, with an inner ball, an outer ring, and a one or two piece brass, bronze, or copper alloy race between. Since the early 1950’s users of these bearings, which are also marketed with a “FLBG”, “RS”, or “VBC” prefix, have had to accept the low strength and poor vibration resistance of these bearings do to the low strength race material. Aurora’s LCOM bearings incorporate superior materials and manufacturing processes to overcome the performance deficiencies associated with “LS” bearings.
www.aurorabearing.com
Filed Under: Bearings Tagged With: spherical bearings
