Modern machines and devices use all available process data to optimize them and make them transparent. PROFINET as a communication standard is ideally suited for this. Dunkermotoren early on integrated PROFINET functionality, including the PROFIdrive profile with application classes 1 and 4, into motors as standard. This offers PROFINET users significant advantages in cabling, commissioning and operation.
Only the power supply and bus connection need to be established, and the motor can be integrated into the commissioning environment, e.g. the TIA Portal, and programming can begin. During operation, the controller accesses all motor parameters and uses them for process control, error monitoring, predictive maintenance and many other IIoT or cloud features.
BG 95 dPro PN was the first fully integrated PROFINET motor from Dunkermotoren. BG 66 dPro PN followed at the end of 2020, and the BG 75 dPro PN at the beginning of 2021. Already available is the external control electronics BGE 5510 dPro PN, which shows its advantages especially when the motor length is severely limited or in combination with BG 45. This means that Dunkermotoren customers can use the advantages of PROFINET for drive tasks in the power range from 40 to 1,100 W duration and 4,000 W peak.
For more information, visit www.dunkermotoren.com/en/.
