You are here: Home / Motors / Gearmotors / Bison introduces new 1/2 HP PowerSTAR 730
November 24, 2015 By WTWH Editor Leave a Comment
bisonpr-151124Bison Gear and Engineering is further expanding their PowerSTAR hypoid gearmotor product line with the addition of the 1/2 HP 730 Gearmotor. This new gearmotor improves torque output and energy efficiency while offering the same flexibility in mounting orientation and compact right-angle design footprint that is ideal for space constrained industrial equipment.
The 1/2 HP PowerSTAR 730 Series Gearmotor has standard 1.25 inch hollow bore output shaft sizes. With four standard AC motors (115V Single Phase, 115/230V Dual Voltage/Dual Frequency, 230V 3-Phase Inverter Duty and 230/400-460V 3-Phase Inverter Duty) and 7 standard gear ratios ranging from 10:1 to 60:1, the 730 Series product line has the ability to meet most industrial requirements. Custom options are also available per request; consult Bison directly for more information.
The 1/2 HP PowerSTAR 730 Series Gearmotor is now available. Check performance ratings, 3D models, drawings and pricing at bisongear.com.
Bison Gear & Engineering Corp.
www.bisongear.com
Filed Under: Gearmotors, Gears + Gearing Tagged With: bison
