You are here: Home / Motors / DC Motors / Bodine Introduces New DC Motor Speed Control with Dynamic Braking
★ By Jennifer Calhoon Leave a Comment
Bodine Electric Co. expanded its extensive family of DC motor speed controls to include a new enclosed model with forward-brake-reverse switch and dynamic braking. The new control is ideal for use in bi-directional applications such as conveyors, packaging machines, screen-printing equipment, food processing applications, medical devices, lab instrumentation and labeling equipment.
Bodine
Housed in a NEMA 1/IP-20 enclosure, the new model 0794 provides smooth speed control for PMDC gearmotors and motors. Its pulse width modulated (PWM) design provides higher torque and lower motor operating temperatures than typical SCR controls. Filtered DC output to the motor allows cooler operation, longer brush life, lower audible noise, and wider speed range. The type “WPM” control accepts 115 VAC, 50/60 Hz, 1-phase input. Motor power ratings are 7/16 HP (326 Watts) at 90 VDC, or 5/8 HP (466 Watts) at 130 VDC.
This stock model features a forward-brake-reverse switch, allowing dynamic braking for applications where the motor needs to be manually and infrequently reversed, or when required as a setup function in an application.
Five trim-pot adjustments (TORQ limit, MIN and MAX speed, acceleration/deceleration, and IR compensation) eliminate the computer-like programming required in other drives. DIP switches allow the control to be easily calibrated for different motor sizes. Two Diagnostic LEDs on the PC board indicate when power is on and when current output is at limit set by the TORQ pot.
Availability
The model 0794 is available through Bodine’’s distributor network, via direct sales to OEMs, or from the Bodine web site. Stock orders typically ship within 2-3 business days.
Bodine Electric
www.bodine-electric.com
Filed Under: DC Motors, Gearmotors, Industry News, Motors Tagged With: bodineelectric
