You are here: Home / Mechanical PT / Gears + Gearing / CGI, Inc’s RC/DC Series: Prime Right Angle Gearhead
May 1, 2014 By Jennifer Calhoon Leave a Comment
CGI,-IncCGI, Inc. features its RC/DC Series: Prime Right Angle Gearhead. Construction Features Include:
  • True planetary design
  • Tapered roller bearings
  • Low backlash design
  • Input pinion with balanced clamp collar
  • Quick installation
  • Strong, caged roller bearings
  • High reliability design
  • High strength steels
  • High shaft loading capacity
  • Viton O-Rings sealed at each joint
  • Case hardened spiral bevel gears
  • Sealed ball bearings
  • High efficiency design
  • All gears are heat treated
  • 5 year warranty
CGI, Inc’s precision gearheads give you the competitive advantage by providing the best value for precise positioning gear solutions. With thousands of successful applications in nearly every industry, and more than 40 years of manufacturing excellence, CGI, Inc. can provide the solutions for your motion control applications.
CGI, Inc.
www.cgimotion.com
Filed Under: Gears + Gearing, Mechanical PT Tagged With: CGI Motion
