Copley Controls has released the R47 and R48 NanoPlus Micro Module servo drives. The drives are hardened versions of Copley’s NPS drive and are designed for applications exposed to temperature extremes, high humidity, vibration and shock. Their compact form factor supports installations with limited space.
The R47 communicates over CANopen, while the R48 uses the CANopen application protocol over EtherCAT (CoE). Both drives use the same FPGA-based NanoPlus architecture, mechanical footprint and feature set. They are available as bare micro modules for direct mounting to a user’s circuit board or preassembled on a ruggedized EZ board.
The drives operate from 9 to 90 VDC or 20 to 180 VDC input. They provide continuous current ratings of up to 35 A, peak current of up to 70 A, continuous output power of up to 3.15 kW and peak output power of up to 6.3 kW.
Additional features and specifications include:
- Bare module dimensions of 1.38 × 1.18 × 0.86 inches and a weight of 1.2 ounces.
- Safe Torque Off (STO) with SIL 3, Category 3 and Performance Level e conformance.
- Operating temperatures from -40 to 70 C.
- Vibration resistance to 3.85 grms.
- Shock resistance to 75 g during crashes and 40 g during operation.
- A 16-kHz current-loop update rate and 4-kHz position- and velocity-loop update rates.
- Seven high-speed digital inputs and six high-speed digital outputs.
- Encoder interfaces for BiSS, SSI, EnDat, Absolute A, Sin/Cos, digital quadrature and digital Hall signals.
- Built-in Ethernet on the R48, with support for UDP, TCP/IP, Modbus TCP and EtherNet/IP.
The R-Series drives are designed to conform to IEC 61508 (SIL 3), ISO 13849-1 (Category 3, Performance Level e), IEC 61800-5-1, IEC 61800-5-2, IEC 61800-3 for electromagnetic compatibility and RoHS requirements. They are also designed to meet MIL-STD-461, MIL-STD-704, MIL-STD-810, MIL-STD-1275 and MIL-STD-1399. UL recognition and other agency approvals are pending.
The drives are intended for commercial off-the-shelf military, marine, aviation, oil-refining and vehicle-based systems that operate in harsh environments.
For more information, visit copleycontrols.com.
