Crouzet North America (www.crouzet.com) proudly introduces the latest 801 Series Brushless DC Gearmotor, which features integrated Gearbox and electronics. The all-in-one solution offers flexible control for torque and speed in a compact, sealed package. Without brushes to wear out, it suits well for lab automation, medical equipment and industrial applications where longer product life and reliability is important.
“Typically, motors, gearboxes and controllers are purchased separately,” said Jim McNamara, Application Engineer at Crouzet. “With Crouzet’s new integrated package, customers have a convenient way to purchase all three functions in one product from a single supplier.”
With the addition of this new product, Crouzet has expanded its capabilities. Its product line’s torque range has increased to 120Nm, while its power rating has improved from 80 watts to 205 watts. The product’s planetary models feature speeds from 7 rpm to 627 rpm, while right angle units offer speeds from 44 rpm to 440 rpm. Each 801 model is designed with a standard IP54 sealing and integrated electronics.
The series measures only 57mm square and can easily fit into applications with tight packaging constraints. The product’s sealed packaging enables users to use it even under harsh environments. It also comes with a cast aluminum housing, which optimizes robust operation and durability. Standard models can be modified in Crouzet’s Custom Adaptation Center to suit specific application needs such as higher IP seal ratings, custom mounting options or supplying with no integrated controls.
