You are here: Home / Motors / Custom Direct-Drive Motor Assemblies from Applimotion
August 22, 2013 By Miles Budimir Leave a Comment
Loomis, CA – Applimotion offers custom direct-drive motor assemblies with its ULT, UTH, UTS and UTO brushless frameless motor kits. These assemblies typically include precision bearings, special encoders, special mounting features, and cabling to provide a low-profile direct-drive solution. With sizes ranging from 10 mm to 500 mm in diameter, pancake profiles as low as 10 mm and large through holes, a custom direct-drive solution may be the best approach to automation needs covering torque from 0.1 to 1000 NM. Aug 2013 PR_Rev1
These custom direct-drive motors are typically used in automated inspection, metrology, material handling, medical diagnostics, as well as robotics and factory automation. A unique feature of these direct-drive solutions is the ability to cover a wide range of speeds, even high speed which is not typical for direct-drive motors, to very low sub-rpm speeds.
For more information, visit www.applimotion.com.
Filed Under: Motors
