You are here: Home / Mechanical PT / Gears + Gearing / Custom High Torque Gear Motors from Applimotion
December 5, 2012 By Miles Budimir Leave a Comment
Loomis, Cal. – Applimotion has introduced custom gear motors for high torque, low speed and low profile applications. The assemblies combine precision gearing and direct drive frameless motor kits to form a new high torque alternative to coupling a servo motor to a traditional gear box.
Applimotion combines its ULT, UTH, and UTS low-profile frameless motors with the right gearing solution. Combining direct drive motor technology with the appropriate gearing solution may be the best alternative for smoothness, low speed, high torque and low profile package. These assemblies include precision bearings and high-resolution encoders, and the can run with any traditional servo controller.
Applimotion can create custom gear motor assemblies ranging in size from 25 mm to 800 mm diameter. If you don’t have the time or experience designing custom motor assemblies, and you have a unique application, Applimotion can turnkey the project for you. Design engineers are experienced and available to talk about your needs and quickly work to a solution.
For more information, visit www.applimotion.com.
Filed Under: Gears + Gearing, Mechanical PT, Motors
