You are here: Home / Motors / Customized hypoid right-angle gearmotors from Power Electric
Power Electric has developed a new right angle gearmotor with hypoid gears in an all-in-one compact size. The hypoid gears bring distinct heavy load bearing capabilities and provide extremely efficient operation. This right angle gearmotor is fully customizable to customer requirements and specifications.
The gearmotors feature rated torque of 21 Nm, a 200:1 gear ratio, and rated current of 0.45 A. They also feature low noise output, high efficiency, and are durable and able to withstand extreme weather conditions. Specifications are adjustable based on application requirements and they can be fully customized for customer requirements regarding food-grade lubrication, for example.
For more information on the gearmotors, visit www.powerelectric.com.
gearmotors
Filed Under: Gearmotors, Motors
