You are here: Home / Networking + IoT / Sensors + Vision / Global.CProx Capacitive Proximity Sensors from Balluff
February 9, 2011 By Miles Budimir Leave a Comment
Florence, Ky. – Balluff’s new Global.CProx line of capacitive sensors offers a broad range of products to reliably solve object and level detection applications. The Global.CProx family includes a wide array of tubular M12, M18 and M30 sensors available with either M12 connectors or pre-wired cables. Built to Balluff’s high standards, all of the Global.CProx sensors offer reverse polarity and short circuit protection with enhanced EMC protection.
Flush-mount versions of these sensors can detect objects up to 15mm away, regardless of color, texture or material. Non-flush mount versions of the Global.CProx sensor line are ideal for level detection of bulk material or liquids either directly or through a plastic or glass container wall, with sensing distances up to 25mm.
Global.CProx Sensors feature stainless steel or plastic housings, PNP and NPN versions with normally open or normally closed outputs, large green power on LED, large yellow output LED, as well as high EMC noise immunity, extended switching distances and improved adhesion compensation through non-flush switching characteristic.
For more information visit: www.balluff.com/global.cprox
www.balluff.com
Filed Under: Sensors + Vision
