The Model MA58H absolute encoder from Encoder Products Co. (EPC) is heavy duty, rugged and reliable. This multi-turn hollow-bore absolute encoder is designed for harsh factory and plant floor environments … and is especially suited to applications where you need an encoder with the capability of output even in power-off scenarios. The Model MA58H has an operating temperature range of -40° C to 85° C and a sealing rating of IP65 on the shaft, with the balance of the unit rated to IP67. Available in both single turn or multi-turn, with bores up to 3/8 in. or 14 mm, and with two flexible mounting options, the Model MA58H is easily designed into a variety of applications.
Versatile and configurable: With a variety of mechanical and electrical options, the Model MA58H can be configured for almost any application. For more information, visit encoder.com.
SSI or CANopen? Whether the application calls for SSI or CANopen communication protocol, EPC has literature and design engineers to help OEM designers make the most suitable choice. Download a PDF on SSI from EPC as well.
