You are here: Home / Featured / IP65 integrated stepper motors from Applied Motion
May 22, 2017 By Lisa Eitel Leave a Comment
SWM integrated steppers are IP65 rated drive+motor units, fusing step motor and drive components into a single splashproof and dustproof device. This space—saving design eliminates wiring and saves on cost over conventional motor and drive solutions.
The SWM24 integrated steppers combine high torque NEMA 24 step motors with a sophisticated, 6.0 A/phase (peak-of-sine) step motor drive. Power to the drive, located at the rear of the motor, must be supplied by an external DC supply. Applied Motion offers compatible 24 and 48-volt DC power supplies for exactly this purpose.
All SWM24 integrated steppers are RoHS and CE compliant. Features include:
Torque to 340 oz-in.; Rated IP65 for wet and dusty environments
Torque ripple smoothing; M12 connectors; Anti-resonance; Microstep emulation
Stored programming option for stand-alone operation; NEMA 24 frame size
Step direction, velocity and streaming command control modes
RS-232, Ethernet and EtherNet/IP Communication options
Modbus/RTU for easy communication with PLC or HMI; Built-in incremental encoder
Click here for more information on the SWM24 IP65 Integrated Step Motor from Applied Motion Products.
Filed Under: Featured, Motors, Stepper Motors Tagged With: appliedmotion
