You are here: Home / Motors / LR17 Piezo LEGS® Rotary Motor from MICROMO
★ By Patrick Curran Leave a Comment
The new LR17 expands MICROMO’s line-up of piezo technology from PiezoMotor and is offered with an integrated absolute encoder.
The compact LR 17 is a mere 17 mm in diameter and has all the benefits coming from the Piezo LEGS technology. The stall torque from the motor is 30 mNm, which is high compared to its small size. Because of the self-locking feature of the friction drive, the motor can hold position without consuming any power. The integrated 15 bit magnetic absolute encoder gives a closed loop resolution of 0.2 milli-radians (0.01°). Through the Piezo LEGS technology, you get an amazing sub-micro-radian resolution in open loop.
MICROMO-LR17-Piezo-LEGS-Rotary-Motor
“The LR17 is the first motor in a series with four different sizes. It allows our customers to have a very compact motion solution, including sensor for easy integration. It follows our motto – Simplicity in Motion. The Piezo LEGS technology makes it possible to continue improving existing customer design when conventional motor technology has reached their limits” says Anders Larsson, Sales & Development manager at PiezoMotor.
PiezoMotor AB
www.piezomotor.se
MICROMO
www.micromo.com
Filed Under: Motors, Piezo Motors Tagged With: MICROMO of Faulhaber, piezomotor
