MISUMI USA, Inc. (http://us.misumi-ec.com), a fully-owned subsidiary of MISUMI Corporation (www.misumi.co.jp), is proud to launch several new products to add to its expansive line of configurable Linear Guides for motion control equipment and machinery.
The all-new Linear Guides from MISUMI will include: SX2RD (dual block) and SXRD (single block) Heavy Load, and SV2RD (dual block) and SVRD (single block) Medium Load versions which are double-sealed, along with an added side seal to enhance sealing as well as preventing any intrusion of machining chips, dust or other debris into the guide rail. The double-sealed versions of SX2RK (dual block) and SXRK (single block) Heavy Load, and SV2RK (dual block) and SVRK (single block) Medium Load provide a metal scraper integrated in the external side seal that automatically remove any large pieces of hot welding spatter or foreign material from the guide rail.
Ruggedly constructed of carbon steel, these Linear Guides can be precisely configured to a wide range of specifications such as height, length, load rating, and tapped hole machining.
Moreover, MISUMI offers a comprehensive line of advanced and standard Linear Guides in multiple configurations and sizes to add to the new dust-proof heavy and medium load versions. These include long and wide blocks, interchangeable, small clearance and preload types. All of the Linear Guides from MISUMI can operate under a temperature range from -20°C to 80°C, and are designed to precise dimensional tolerances. The Linear Guides can be selected and configured by design engineers to their specific requirements relative to thrust, friction resistance, load, and rated life span, conveniently using calculations and tables provided in MISUMI’s online or print Metric Catalog.
