You are here: Home / Motors / Motor series from Lin Engineering features high torque
May 6, 2021 By Miles Budimir Leave a Comment
Lin Engineering high-performance X-series motors deliver higher power density than ever before. The X5718 comes in a NEMA 23 (56.4 mm) frame size. High power density means that these motors can deliver more torque at a targeted speed than competitors’ motor of the same size. This is due to a unique motor design which provides exceptional torque to size ratio. The X-Series motors deliver:
  • Higher dynamic torque
  • Higher speed
  • Smaller size
  • Reduced weight
  • Higher efficiency per watt for battery operated devices
  • Reduced heat generation
  • Higher efficiency at lower voltage
motor
Lin Engineering offers more than just off-the-shelf solutions. For OEM type applications, they can customize the X-series motors to ensure optimal performance within the parameters of the specific application.
For more information, visit www.linengineering.com.
Filed Under: Motors Tagged With: Lin Engineering
