You are here: Home / Drives + Supplies / New Harmonic Drive SHA-CG hollow-shaft actuators serve as direct drives
November 5, 2015 By Lisa Eitel Leave a Comment
Harmonic Drive LLC now sells actuators with surface run-out of less than 10 μm. These SHA-CG models are the newest rotary actuators from the manufacturer.
The SHA-CG units have a compact and hollow-shaft configuration to satisfy an array of applications.
Ideal for machine tool applications, the SHA Series of brushless actuators provide high torque for fast acceleration and positioning.
SHA-CG actuators are composed of a Harmonic Drive CSG zero-backlash gear combined with a brushless servomotor with an encoder resolution at the output up to 20,971,520 pulse/rev.
The actuators also come with an optional brake. Positional accuracy exceeds 1 arc-min and repeatability is better than ±5 arc-sec; torque output is to 3,400 Nm.
A robust cross-roller bearing allows mounting of large loads directly to the actuator without the need for additional support.
The SHA-CG has a torque-to-weight ratio to eight times that of comparable housed direct-drive motors, and a torque-to-volume ratio to six times greater … for a more compact and light-weight machine design.
SHA-CG direct-drive specifications
High accuracy with a zero-backlash Harmonic Drive gear reducer; compact, flat, hollow shaft
Hollow-shaft diameter from 17 to 45 mm
Available in four sizes … 20, 25, 32, 40
Speeds to 120 rpm
Related: New website and selector tool for Harmonic Drive gearheads
Harmonic Drive LLC now has a new website for Quick Connect gearheads at harmonicdrivegearhead.com. The site features a Product Selector Tool, 360° images, and full specifications …
Related: Top gear trend in 2015: Custom designs faster
Power-transmission devices are increasingly customized, and gearsets and gearmotors are no exception. However, today’s custom and standard gear products aren’t mutually exclusive …
Related: What are Power-Transmission Gears? Technical Summary
Updated May 2015 by Lisa Eitel. || The function of a gear is to mesh with other gears to transmit altered torque and rotation …
Filed Under: Drives + Supplies, Gearmotors, Gears + Gearing Tagged With: Harmonic Dri
