You are here: Home / Integrated Motion Systems / New Micro-Positioning Components and Solutions catalog from PI
PI (Physik Instrumente) has released a new catalog of engineered products necessary for precision positioning of medium loads used in industry and research.stages
The products highlighted in the catalog are developed to move loads of 10 to 50 kg (22 to 110 lb) over distances up to 300 mm. Rotation stages provide rotation angles of 360 degrees. Achieving accuracy in the micron and sub-micron realm is not a trivial matter and stages with ballscrew/servo or stepper drives combinations can be superior to direct-drive motors when it’s necessary to achieve high holding force, torque or particularly for vertical positioning.
Linear and rotary stages are also available in compact sizes for easy installation into limited space.
You can download the new Precision Motion Control Solutions catalog at the link here: http://www.pi-usa.us/pdf/index.php#MicropositioningCat.
www.pi-usa.us
Filed Under: Gantries + Stages, Integrated Motion Systems Tagged With: physikinstrumente
