You are here: Home / Controls / New motion controller, remote I/O module from AutomationDirect
AutomationDirect has added PS-AMC motion controllers designed to work seamlessly with select Productivity PLCs to provide accurate, coordinated, plug-and-play motion control. These controllers are capable of up to four coordinated axes of motion per controller (PS-AMC4) with differential encoder feedback for each axis and a maximum switching frequency of 1 MHz. Up to 24 general-purpose high-speed inputs and 12 general-purpose high-speed outputs are also included.
Available in 1, 2, 3, or 4-axis models, AMC controllers are auto-discovered in the Productivity Suite programming software, which has numerous built-in motion instructions allowing for easy configuration of standard motion profiles, including flying cut-offs and rotary tables.
motion controller
The Productivity1000 remote I/O module provides a low-cost remote I/O solution for both the P1-550 and P2-550 controllers. Up to four P1-RX remote modules can be used with the P1-550, and up to eight can be used with the P2-550. That adds an additional 512 I/O points to the P1000 system, which did not offer remote expansion before, and an additional 1,024 for the P2000 at a much lower cost than the existing P2-RS expansion module. All P1-RX modules and connected I/O are auto-discovered in the Productivity Suite programming software with pre-assigned tags for each I/O point that can be used right away in the ladder code or modified as needed.
The new PS-AMC Motions Controllers start at $284, and the P1-RX Remote I/O Module is priced at $85.
For more information, visit www.automationdirect.com.
Filed Under: Controls, Stand-Alone Controllers Tagged With: AutomationDirect
