You are here: Home / Integrated Motion Systems / Gantries + Stages / New Rotary Table from Techno Inc.
New Hyde Park, NY – Techno, Inc. Linear Motion Systems announces the new Rotary Table RF, a variable speed, infinite positioning rotary table that can be used in various industrial applications. Offered with optional accessories, magnetic brake, 3-jaw chuck and 490mm diameter flat disk, the new RF provides users the ability to complete applications without going to multiple vendors. The Rotary Table RF is available with stepper or servomotor and several different ratios, providing high-speed or high-torque options.
The Rotary Table RF can take loads up to 170 lbs. It has a footprint of 410 x 275mm and a height of 122mm (stepper option) and 200mm (servomotor option). Additionally, it can be mounted horizontally or vertically. This low backlash, rotary table is compact and sturdy, set in a rigid cast aluminum body.
Each Rotary Table RF is complete with a hardened, ground and flat milled steel rotary surface. Maximum output torque is 188Nm and is available in 24:1, 52:1, and 100:1 ratios. Techno’s Rotary Table RF is ideal for use in pick and place, assembly, testing, inspection and dispensing applications.
View CAD Drawings, catalog specifications and more information on the New Rotary Table RF online at: http://www.techno-isel.com/Tic/Catdas/rotaryRF.htm
www.techno-isel.com
Filed Under: Gantries + Stages Tagged With: stage
