You are here: Home / Integrated Motion Systems / Gantries + Stages / Bell Everman introduces new ServoBelt rotary stage family
October 6, 2016 By Lisa Eitel Leave a Comment
ServoBelt Rotary Stages from Bell Everman are compact, high-torque rotary stages that offer through hole size and speed comparable to direct-drive rotary tables costing thousands more.  Features include …
Room in the middle. ServoBelt Rotary stages offer two different through hole configurations. Available with 50-, 100- or 200-mm center openings, our large through hole stages accommodate large bundles of power, signal and pnuematic conductors. They also make it easy to integrate laser and optical systems. Standard-sized models with 16- or 25-mm through holes offer a more economical choice when fewer utilities need to pass through the center of the stage.
Direct-drive performance. Designed for NEMA 23 and 34 motors, the ServoBelt rotary stages offer speeds up to 1,000 rpm, continuous torque to 6.6 N-m and resolution down to 0.16 arc-sec with Renishaw ring encoders or tape scales for partial rotation.
new-servobelt-rotary-stage-family-from-bell-everman
Application flexibility. ServoBelt Rotary stages support both continuous rotation and variable indexing applications.
Robust lubed-for-life bearings. ServoBelt Rotary stages incorporate large full duplex, angular contact bearings, imparting moment and load capacities far in excess of its usual application requirements. This excess load capacity translates into virtually limitless bearing life.
Cost effectiveness. ServoBelt Rotary stages offer an economical solution for a variety of medium-duty rotary motion jobs such as driving carousel tables on packaging and assembly machines and providing fourth-axis rotary motion for laser cutting and mini CNC machines.
Click here to get a PDF with more information on the stages from Bell Everman.
Filed Under: Featured, Gantries + Stages, Integrated Motion Systems Tagged With: belleverman
