You are here: Home / Encoders / Absolute Encoders / Rotalink’s low-cost absolute encoders with ovoid gearboxes
September 7, 2010 By Motion Control Tips Editor Leave a Comment
Rotalink (www.rotalink.com) has unveiled an innovative low-priced absolute encoder with ovoid style gearboxes. This compact encoder is directly fitted to the output shaft’s rear side to measure the load position and it is available for single-turn 360° rotation or multi-turn versions of up to 32,000 revolutions. The absolute encoder uses highly reliable and long-life non-contacting magnetic technology and provides a choice of a 10-bit per turn positional data or 0V-5V linear analogue output through a synchronous serial interface (SSI).
The device can be used to replace potentiometer-based angle encoders by combining position and motor feedback in one component or for low-cost servo feedback in rotary and linear actuators. Absolute position feedback is also very useful for machine homing. The device’s multi-turn option consists of an integral rechargeable battery, which maintains full position information for 20 hours if machine power is removed,
Rotalink designs and produces a variety of gearboxes in spur and planetary gearbox designs that feature polymer gears on ball or sintered bearings. The range also consists of ovoid-style gearheads, which include planetary gear assemblies for the output stages and a combination of spur gears for input stages. These are available in a choice of ultra-polymer materials.
The new absolute encoders are included in the company’s latest catalogue, which also features three new ranges of DC motor technologies – brushless, rare earth and heavy case – and new brushless version of the Red Drive motion controller and several gearbox lines.
Filed Under: Absolute Encoders, Encoders, Gears + Gearing, Mechanical PT
