New Hyde Park, NY – The Rotary Table RF from Techno, Inc. Linear Motion Systems is a variable speed, infinite positioning rotary table that can be used in various industrial applications, replacing cam-driven tables with more versatility at half the cost. The RF is offered with optional accessories, magnetic brake, 3-Jaw Chuck and 490mm diameter flat disk, and is available with stepper or servomotor and several different ratios, thus providing high-speed or high-torque options.
The Rotary Table RF can handle loads up to 170lbs., has a footprint of 410 x 275mm and a height of 122mm (stepper option) and 200mm (servomotor option), and can be mounted horizontally or vertically. This low backlash, rotary table is compact and sturdy, set in a rigid cast aluminum body.
Each Rotary Table RF is complete with a hardened, ground and flat-milled steel rotary surface. Maximum output torque is 188Nm and is available in 24:1, 52:1, and 100:1 ratios. Users can choose between high-speed or high-torque options, based upon their application requirements. Techno’s Rotary Table RF is ideal for use in pick-and-place, assembly, testing, inspection and dispensing applications.
View CAD Drawings, catalog specifications and more information on the New Rotary Table RF online at: http://www.techno-isel.com/Tic/Catdas/rotaryRF.htm, or call 1-800-819-3366 to speak with an application engineer or email: [email protected].
