RS, a global product and service solutions provider for industrial customers, offers Schneider Electric’s TeSys Tera motor management system. The product is designed to retrofit standalone control cabinets and intelligent motor control center (iMCC) panel buckets, adding monitoring and control functions for pumps, fans and motor drives in older facilities. It is intended to help operators move from reactive troubleshooting to condition-based maintenance.
Motor failures, energy costs and aging infrastructure continue to create challenges for industrial plants. TeSys Tera replaces hardwired electromechanical starters with connected control nodes and provides digital visibility into motor operation. It supports AC induction motors up to 810A and is designed to help operators monitor performance, identify issues earlier and improve energy use.
Key capabilities include:
- Motor protection and diagnostics: Tracks voltage, current, power factor and thermal capacity, with protection for ground faults, phase loss and stalled or locked rotors.
- Pre-trip alarming: Uses analytics to identify abnormal operating conditions before failures occur so maintenance can be scheduled in advance.
- Process continuity: Restarts equipment after power interruptions and can reduce nonessential motor use during peak demand periods.
- Retrofit-ready design: Uses a compact modular architecture that separates power and control functions and fits existing systems without full replacement.
- Connectivity: Supports EtherNet/IP, Modbus TCP/IP, Modbus Serial, PROFIBUS and PROFINET, along with Schneider Electric SoMove software for PLC integration.
TeSys Tera is aimed at new continuous-process facilities, iMCC retrofits and applications in oil and gas, mining, chemical, pharmaceutical, water and wastewater, packaging and discrete manufacturing.
For more information, visit rsgroup.com.
