Pepperl+Fuchs introduces RVS58S Safety Encoders and VBA-2E-KE4-ENC-S AS-Interface Encoder Input Modules. This safe motion solution improves machine productivity and enhances worker safety by detecting zero-speed, over-speed and motion direction to ensure safe machine
access during setup and maintenance. The system easily integrates into new machines or existing equipment, and is ideal in applications that demand SIL3, PL e and Category 4 certification.
RVS58S incremental encoders have a sin/cos interface, 1024 or 2048 signal periods and are thermally stabilized for high resolution interpolation. They operate at 5 VDC ±5% and deliver a maximum output frequency of 200 kHz in operating temperatures ranging from -20 °C …80 °C (253 K …353 K). They are rated to handle axial shaft loads of 40 N at maximum 6000 RPM or 10 N at maximum 12,000 RPM, and radial shaft loads of 60 N at maximum 6000 RPM or 20 N at maximum 12,000 RPM.
VBA-2E-KE4-ENC-S AS-Interface safety modules feature a compact 22.5 mm wide housing to minimize cabinet space requirements, and quickly snap into place on a standard 35 mm mounting rail. Each module provides two safe inputs for incremental encoders that monitor the standstill, rotational speed and direction of rotation on up to two axes of motion, and sends a safe signal via the AS-Interface network when a value falls below a set threshold.
Pepperl+Fuchs
www.pepperl-fuchs.us
