You are here: Home / Featured / Stafford’s Accu-Mount™ Collar
September 30, 2009 By Motion Control Tips Editor Leave a Comment
Wilmington, MA – Stafford Manufacturing Corp. offers a line of collars that provide an effective method for mounting sprockets, gears, pulleys and other components on a shaft, without marring the shaft.
Stafford’s Accu-Mount™ Collar has a smooth bore that won’t mar shafts and a centering hub with a square and flat side that features four predrilled and tapped holes for attaching components. Designed for rigidly mounting a wide range of drive components such as sprockets, gears, and pulleys, this collar is easy to adjust and remove for final set-up and scheduled maintenance.
Providing a wobble-free component mounting method, Stafford Accu-Mount™ Collars are machined from steel in 11 sizes from 0.5” to 2.0” I.D. and are supplied with a keyway. Easy to move and remove, they are suitable for a wide range of machinery building and conveyor system applications.
Stafford Manufacturing Corporation
www.staffordmfg.com
Filed Under: Featured, Mechanical PT Tagged With: shaft collars, stafford manufacturing
