You are here: Home / Drives + Supplies / STR Step Motor Drives from Applied Motion Products
WATSONVILLE, CA – Applied Motion Products introduces the STR, a new drive engineered to deliver the features expected by today’s machine builders, at a price they need. The STR step motor drives, available in 4 amp and 8 amp versions, are DC input drives requiring a step and direction control signal. They feature Anti-resonance, Microstep Emulation and Idle Current Reduction.
Configuration is done entirely with switches on the drive. AMP engineers optimized the performance for a number of motors, storing all the configuration parameters on the drive. The motor is then selected by a 16 position rotary switch. Custom configurations are welcomed for OEMs wishing to use a different motor. The STR is compact, measuring only 4.64” x 2.97” x 1.29”.
www.applied-motion.com
Filed Under: Drives + Supplies, Stepper Drives Tagged With: Applied Motion Products, str step drive
