You are here: Home / Networking + IoT / Sensors + Vision / Terminal Chamber for uprox®+ Sensors
April 17, 2009 By Miles Budimir Leave a Comment
tus-343-300dpi
Minneapolis, MN – TURCK has introduced an integrated terminal chamber for its line of uprox®+ sensors that conforms to FDA requirements for washdown environments, including food and beverage industry applications such as dairies, breweries and bakeries. The terminal chamber includes removable terminals for quick and easy mounting using screws or cage clamps. By simply rotating the cover by 180 degrees, users can select either a straight or 90-degree cable exit.
TURCK’s uprox+ line of factor 1 sensors detects all metals at the same rated distance and meets the requirements for food-safe materials. The sensors are available in 12, 18 and 30 mm stainless steel barrels with a liquid crystal polymer (LCP) front cap that is impermeable to cleaning agents, disinfectants, high pressure and steam cleaning.
For additional product or technical information, contact: 1-800-544-7769 or email turckusa@turck.com.
www.turck.us
Filed Under: Sensors + Vision
