You are here: Home / Encoders / US Digital E8P Optical Kit Encoder
US Digital announces the release of its latest encoder in a line of high performance, low cost solutions for motor feedback applications: the model E8P.
The E8P is specifically designed to fit on NEMA Size 11 motor frames and provides incremental encoder feedback information. The E8P’s unique collet style, push on hubdisk assembly eliminates the need to rely upon the set screw to retain the code wheel to a shaft. Standard bore sizes range from 3mm up to 7mm; single ended and differential outputs are readily available. If you have a size 11 stepper motor which requires encoder feedback, the E8P is the ideal product for your application. The E8P pricing starts at $33.95 for quantity 1 and is $16.95 at 100 units. US Digital encoders are available to ship the same day if the order is received before 1:00pm Pacific Time.
US Digital
www.usdigital.com
Filed Under: Encoders Tagged With: optical encoder, us digital
