You are here: Home / Motors / Wing Motor Split Motor Design from Wittenstein
December 9, 2011 By Miles Budimir Leave a Comment
Bartlett, Ill. – Wittenstein’s swing servo motor, also known as the wing motor because of it’s appearance, is the newest innovative mounting concept in motor mounting, originally created as a customized solution. WITTENSTEIN motor
The hollow-shaft direct drive wing motor has two swinging stator halves that feature a mounting concept for unique integration and operating scenarios where axial installation and removal in or from a machine are not possible. The split stator contains two parallel, three-phase systems which allow for the stator to be joined together in a controlled way. Each stator half contains a water-cooling pipe system made from stainless steel. It prevents damage to the drive due to intense heat stemming from the roll. It can be retrofitted or dismantled at any time for maintenance, and is designed to withstand the harshest of operating environments.
This motor operates the same way as a classic, one-piece direct drive with impressive performance.
For more information, visit www.wittenstein-us.com.
