You are here: Home / Linear Motion / Actuators / 350 mm aperture motorized rotary actuators
September 8, 2020 By Josh Heney Leave a Comment
ServoBelt Rotary Stage offers an economical solution for a variety of light and medium-duty rotary motion applications.
It features very large clear aperture of 350 mm and provides arc-second resolution when driven from a micro-stepping or brush-less servomotor controller.
The low profile design is made possible by the use of compact precision bearing. The rotating carriage of the stage provides unlimited motorized rotation angle of the load up to 100 kg and has large clear aperture to allow the passage of the optical path or cables directly through the stage.
The main body of the stage is made from lightweight anodized aluminum and can attach directly to an optical table or moving linear or XY actuators and can be mounted at any orientation.
ServoBelt stage uses belt drive to achieve high rotating speed.
Lightweight design makes it easy to incorporate this rotary stage into high dynamics XY-Theta multi-axes systems.
MAIN FEATURES:
– Large center aperture 350 mm
– Low profile
– Brush-less servo motor/encoder driven
– Unlimited rotation
– High speed 200 RPM
– Home switch
– Top/bottom motor mount option
IntelLiDrives
http://www.intellidrives.com/
Filed Under: Actuators Tagged With: IntelLiDrives
