You are here: Home / Encoders / BEI’s HS52 explosion proof rotary encoder revealed
October 21, 2011 By Motion Control Tips Editor Leave a Comment
BEI Sensors (www.beisensors.com) has unveiled a space-saving and ultra rugged industrial encoder that meets the required standards and certifications for use in potentially explosive environments. Model HS52 is the industry’s first ATEX and UL rated explosion proof hollow shaft encoder.
This rotary encoder can be operated directly in Zone 1 and Division 1 work environments where ignitable concentrations of flammable liquids vapors or gases are likely to exist in normal operating conditions.
The reliable and rugged rotary encoder eliminates the need for an accompanying Intrinsic Safety barrier, effectively simplifying installation. This also results to a more streamlined feedback system for the explosion proof environments.
Utilizing the explosion proof construction method, the HS52 rotary encoder is fitted in an enclosure that has the capability to contain and withstand even the most volatile gas-to-air mixture internal explosion.
The rotary encoder is equipped with a flexible shaft bore design, allowing it to be rigidly mounted to prevent stress to encoder bearings. The design also provides a more secure attachment to the hazardous area conduit fittings.
In addition, the encoder’s compact hollow shaft design provides engineers space-saving advantages not otherwise found in traditional shafted encoders. As ideal position sensing solution for oil and gas industries, the HS52 is also suitable for use in spray painting applications, solvent refining operations and other explosive environments where operating conditions are extreme and space is a premium.
Filed Under: Encoders, Rotary Encoders Tagged With: BEI Sensors
Leave a Reply Cancel reply
MOTION DESIGN GUIDES
RSS Linear Motion Tips
  • Haydon Kerk Pittman launches compact Z-Theta motion platform
  • Three easy ways to specify application requirements for linear motion systems
  • Sourcing linear motion solutions from NSK’s global manufacturing sites
  • Ride the wave of electrification: Off-highway designs with linear actuators
  • What are capacitive sensors and where are they used?
  • Identifying Best-Value Linear Motion Technologies
  • Learn how to reduce noise and distortion in encoders’ signals
  • Helical Planetary Gearboxes: Understanding The Tradeoffs
Tweets from https://twitter.com/Motion_Control/lists/motion-control-tweets
Fastener Engineering
Copyright © 2021 · WTWH Media LLC and its licensors. All rights reserved.
