You are here: Home / Mechanical PT / Bearings / Boca Bearings launches Anti-Reverse Bearings
May 11, 2011 By Motion Control Tips Editor Leave a Comment
Boca Bearings (www.bocabearings.com), one of the trusted names in ceramic bearing technology, has announced the launch of its latest and expanded series of One Way Bearings, which feature a small radial section height and is also known as Anti-Reverse Bearings.
One Way Bearings are lightweight, compact, operate directly on a shaft and are ideal for transmitting high torque. The bearings are specifically designed to transmit torque between the housing and shaft in one direction while allowing free motion in the opposite direction.
One Way Bearings are offered both in a metric and inch series, with and without bearing assemblies. Those without bearing assemblies come in FC, HF and RC versions. The HFL series offers two integral radial bearings positioned on both sides of a needle roller clutch, allowing them to support radial forces in small or tight areas. Its bearing and clutch assembly can be utilized in a temperature ranging from -30°C to 120°C. Meanwhile, oil lubrication is recommended for a working environment above 70°C.
Boca-Bearings-Anti-Reverse-Bearings
Boca Bearings also offers the EWC and the OWC One Way Bearing Series. The One Way Clutch bearings (OWC), which is also known as Origin One Way bearings are high performance bearings that are extra narrow. Allowing free overrun in the opposite direction, the bearings comprise of drawn cup roller clutch and cage and springs. Its CSK series are offered in two designs — the P-one keyway notch and the PP-two keyway notch series. The keyway enables the bearing to securely and perfectly fit into the shaft and provide the machine, appliance or conveyor belt extra torque.
Filed Under: Bearings, Mechanical PT Tagged With: Boca Bearings
