Midwest Motion Products, Inc. (www.midwestmotion.com) has announced the release of the latest DC Gearmotor that comes with four “face mount” M5 threaded holes that are equally spaced on a 40 mm Dia. B.C. — the Model No. MMP-TM57-24V GP52-2076. Measuring 2.24 inches in diameter and 8.35 inches long, the robust Gear Motor accepts any 24 V DC source and features a keyed output shaft of 12 mm diameter by 52 mm long.
At 2.0 rpm, this reversible gearmotor delivers an output of 443 lb. in. (50 Nm) torque. Although it weighs only 4.5 pounds, this compact gearmotor offers an efficient design that requires only 3.6 Amps at 24 V DC to produce its Full Load Torque. This translates into very low noise operation, long life battery charge and lower costs for related drive electronics.
Rated with IP 54 protection level, the gearmotor’s unique design makes it suitable for operation in harsh environments. Its fully compatible speed controls — Model MMP 20A-24V-RSP or MMP 25A-24V help the gearmotor accomplish variable speeds.
The company’s typical options include Failsafe Brakes, Servo Motors with integral Optical Encoders, Analog Tachometers and Planetary Gearheads that comes with standard ratios ranging between 3:1 and 2653:1 as well as standard or low backlash precision gearing. It also offers various Motor Winding Options that include 28V, 12V, 48V, 36V, 90V and 60 Volts DC.
Midwest also offers standard ancillary equipment such as DC Servomotors, DC power supplies, Motor Speed Controls, PWM Servo Amplifiers, Linear Actuators and a vast array of DC gear-motors.
