You are here: Home / Mechanical PT / Gears + Gearing / GAM Introduces the PE Series of Planetary Gear Reducers
August 25, 2009 By Motion Control Tips Editor Leave a Comment
Mount Prospect, IL – GAM Gear has introduced the PE Series of planetary gear reducers. The PE is a low-cost, precision gear reducer suitable for servo or stepper motor applications where consistency, value and price are essential. The design of the gearbox provides a level of quality, performance and durability at a price point that is the best value on the market.
The PE is available in both a metric (50mm to 118mm) and NEMA (NEMA 17 to 42) output face. The ready-to-mount series is available in five standard frame sizes. The PE line offers maximum torque output from 10 Nm to 135 Nm and reduction ratios from 3:1 to 1000:1. The PE is a closed unit that requires no maintenance (lubricated for life). Combine the PE series gearbox with the new EKC Series elastomer/shaft coupling for even greater cost-effectiveness.
GAM Gear
www.gamweb.com
Filed Under: Gears + Gearing, Mechanical PT Tagged With: GAM
