You are here: Home / Networking + IoT / Connections + Sliprings / GORE High Flex Cables
February 20, 2009 By Motion Control Tips Editor Leave a Comment
GORE High Flex Cables provide superior flex life performance and maximum resistance to severe mechanical and environmental stresses. With more than 45 years of experience in the wire and cable industry and extensive knowledge of unique materials, Gore provides reliable solutions to your most demanding cable and assembly needs.
gore-mc-tips-2GORE™ On-Line Design Tool…
For quick lead times and small order quantities try Gore’s interactive design guide. Design GORE™ Trackless Cable, GORE™ High Flex Round Cable, or GORE™ High Flex Flat Cable (Spooled Cable for larger quantities and Discrete Length Cable for cut to length cable).
gore-mc-tips-4GORE™ Trackless Cable and Assemblies…
GORE Trackless Cable Solutions allow automated equipment manufacturers to eliminate cable track and avoid many of the problems associated with cable track such as particulation, vibration, size and weight.
gore-mc-tips-1GORE™ High Flex Flat Cables
GORE High Flex Cables are used in any energy chain or cable track reducing particulation and eliminating the need for dividers.
gore-mc-tips-3GORE™ High Flex Round Cables
GORE™ High Flex Cables are used in applications where flex life reliability is critical. GORE High Flex Cables will provide your application with reliable performance reducing expensive equipment downtime and field repair due to cable failure.
www.gore.com
Filed Under: Connections + Sliprings
