Kent, Oh. – AMETEK Technical and Industrial Products’ new MAE® brand Size 34 (Model HS 200) hybrid stepper motors exhibit superior torque characteristics to power a wide range of industrial equipment applications. Their low detent torque to holding torque ratios deliver smooth and quiet operation and the fine positioning capability required for microstepping.
Their top-to-bottom insulation system incorporating stator insulators and other components enables the steppers to withstand internal temperatures up to 130ºC. Robust design and rugged construction contribute to reliability and long service life.
These hybrid steppers include three versions with step resolutions of 1.8º (200 steps per rev) in full-step mode. Holding torques (bipolar) of 779 oz-in, 1062 oz-in, or 1416 oz-in can be achieved, depending on motor type. All are available in standard NEMA34 mounting configuration.
Other features include precision-honed stators and ground rotors for tight air gap and maximum performance, single- or double-ended shaft extensions, and high-temperature grade neodymium iron bore magnets. Motors can be supplied with 4 leads and single- or double-ended shafts upon request and can additionally be customized with gearboxes, encoders, and other options to satisfy particular application specifications.
Typical applications for these steppers include actuators, packaging machinery, pumps, and other equipment across industries. The motors are CE approved and manufactured according to EN 60034-1 specifications. UL versions are available upon request.
