You are here: Home / Motors / Integrated AC Servo Motor
February 11, 2009 By Motion Control Tips Editor Leave a Comment
In recent years, integrated brushless servo motors from JVL have achieved a very high reputation throughout the world for their ingenious design. The existing range of 50 to 141W and 800W motors has now been supplemented with the introduction of a mid-range 400W model offering 1.3 Nm up to 3000rpm and shortly up to 1200W for highly dynamic applications.
All of these motors are small, compact, and easy to install and set up. The driver, controller, encoder and Hall sensor are all integrated within the motor in a robust, splash-proof housing. The basic motors offer the following standard features:
•Operating commands from PC/PLC via RS232/422/485
•Pulse/Direction or quadrature inputs for electronic gearing
•A+B encoder output
•Velocity and torque control, either controlled digitally or via ±12bit, ±10V inputs
•Positioning via digital interface
•Software-controlled end-of-travel stops
•Selection of acceleration, maximum velocity, torque, etc.
•6th-order servo filter
•Sine commutation with 2048 PPR encoder. (8196 pulses/revolution.)
•Alarm and ”in position” outputs
•3 inputs and 3 outputs for High Speed start/stop and capture applications
•Internal Power Dump
The new MAC400 provides the same features as the larger MAC800 model and in addition offers:
•Absolute multiturn encoder (Q2 2009)
•Prepared for PowerLink; EtherCAT; Ethernet/IP; ProfiNet and SERCOS
•Even lower cost due to newest technology and production techniques
•Improved 2-channel power dump circuit
•2 RS422 channels for encoder in/output and SSI encoder, etc.
•6 IO for capture of position; interrupt, counters, enable, timer and PLC functions
•High-speed serial interface
•Plugable power connectors
•Natural cooling, no fan
The new MAC400 model has been developed because of customer requests for a mid-range solution in the highly successful MAC series. The MAC400 fully lives up to the strict requirements JVL put on all the MAC motors regarding performance, versatility and reliability.
www.jvlusa.com
Filed Under: Motors, Servo Motors Tagged With: JVL
