AutomationDirect’s IronHorse worm gearbox line now includes hollow shaft models in four frame sizes, and six gear ratios from 5:1 to 60:1. Constructed of cast iron one-piece housings, hollow shaft worm gearboxes feature a C-flange input. Designed to change drive direction by 90 degrees, hollow shaft gearboxes are used when space is at a premium, such as for conveyors, or to simplify mechanical design. IronHorse gearboxes are mountable in any direction, except motor pointing up. Prices start at $169.
See the full line of IronHorse gearboxes at www.automationdirect.com/worm-gearboxes
