You are here: Home / Linear Motion / Low Temperature DualVee Guide Wheels
June 4, 2009 By Motion Control Tips Editor Leave a Comment
Pittsburg, CA – – Bishop-Wisecarver Corporation announces the availability of its new low temperature wheel, the latest addition to the company’s signature DualVee product line. Designed primarily to meet the extreme low temperature demands present in the aerospace industry, the low temperature wheel also provides an economical solution for refrigeration and sub-zero climates.
DualVee low temperature wheels are available in sizes 1 through 4 from stock. DualVee low temperature wheels feature type 440C stainless steel balls and races, and type 304 stainless steel retainers, with a special lubricant formulated to withstand service temperatures from -94 to +230°F (-70 to +110°C). Bishop-Wisecarver DualVee wheels are also available from stock in high temperature, washdown, clean room, and stainless versions to satisfy application requirements. DualVee guide wheels can be provided with custom or customer-supplied lubricants, generally within three weeks. Wheels can even be provided completely dry for applications such as food processing and medical devices where the possibility of grease contamination is an issue.
“This addition to the DualVee family of products supports Bishop-Wisecarver’s mission of ‘Motion without limits’, and truly allows us to provide guided motion solutions for all types of critical and extreme environments”, says Pamela Kan, president of Bishop-Wisecarver.
Bishop-Wisecarver
www.bwc.com/products/dual-vee.html#1
Filed Under: Linear Motion Tagged With: Bishop-Wisecarver (BWC)
